Lets discuss "hubcentric" wheels.
The plastic rings do not last may be a somewhat true statement but for reasons other than you have mentioned. The only load that they really see is while installing the wheel. Once it is torqued properly in place; the plastic should not be subjected to additional loads. But during tire rotation, service requiring wheel removal and tire replacement will all excellerate the deterioration of the plastic rings.
The flat flange isn't functional using stock wheels? It's all that holds the wheel on.
Should have said not a flat (ended) nut. Referring to the tapered end of the nut as not being functional for centering. If somebody hasn't played with nuts enough they might mistake the LR nuts for being tapered flange nuts and lead to confusion.
srvguitarslinger
Jul 9, 2012 12:56 AM
EstorilM
Sep 21, 2011 09:31 AM
adiconfidence
Dec 3, 2010 07:46 AM
UVArover02
Feb 3, 2010 12:24 AM
no need for a redbox tonight
