Lock Mechanisms
Old Dec 2, 2008 | 10:42 PM
kraelo's Avatar
Default Lock Mechanisms
Rear door does not unlock all the way, I have to use the key in the rear to get it to unlock. Now the same thing is happening on the passenger front door ...
IDEAS ?
I dont want to touch it until I get some ideas/suggestions
thanks guys !
Old Dec 2, 2008 | 11:04 PM
AK Rover's Avatar
Default RE: Lock Mechanisms
Sounds like the lock actuators are going south and need replaced.
Old Dec 3, 2008 | 09:53 AM
lifewithoutanet's Avatar
Any elaboration on "going south"? The same is true on my 99 DII. First the right back-seat door and now the right passenger. I'm going to pull out the switches in both doors and give them a look-see. Broken connections? Short? Blown motor? I'm going to take a stab at fixing them myself, first. Haven't priced new ones, yet...but it is a LR, so I'm not optimistic.
Have any of you had problems with door locks malfunctioning that you've been able to fix yourself?
-C.
Old Dec 3, 2008 | 10:13 AM
AK Rover's Avatar
I mean that the lock actuators have gone bad. They have quit working. You can check the connections but more than likely it will require replacing the lock actuators.
Old Dec 3, 2008 | 10:22 AM
I have had one l/r actuator, that when cold, it takes to hits with the remote to raise the lock button all the way up, and I live with it.
The switch is rarely ever the problem. Sometimes just doing in a lubing the actuator will fix the probem, some time it requires replacement.
For $95 you can buy good guaranteed used actuators at, http://www.roverlandparts.com/doorlatchactuators_1.aspx
Old Dec 3, 2008 | 10:40 AM
Thanks, Mike. I'll try to repair myself first, but will go there if I have to order new ones.
-C.
Old Mar 1, 2009 | 07:07 PM
grussell's Avatar
I just took my rear door apart because I could not open it without turning the key to the left while pulling the handle. I discovered the broken spring. I can not find the link to the guy that sells the springs, anyone have it handy?
Old Mar 1, 2009 | 08:50 PM
okdiscoguy's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...m=140259170997
cornbreadj
Dec 27, 2014 07:50 PM
Atwine
Nov 20, 2014 05:25 AM
jakethekid
Oct 3, 2014 09:22 AM
kpl1228
Aug 19, 2012 05:33 PM
dparham
Oct 30, 2011 12:06 PM
