Long travel for D2
Old Oct 16, 2019 | 08:56 AM
whowa004's Avatar
Originally Posted by COSitsWORTHit
I’m on 10in travel Foxes with a 4in lift and sway at disconnects. I can unseat my front springs on that setup.
On the rear, I still have oem watts linkage. Going to go panhard on the rear to get the travel I want. Also I deleted the rear sway bar
I've spoken with some guys near me running the panhard and said they wouldn't do it again. They are running 35s and 6" or so, they swapped from aftermarket watts to the panhard and to them they felt the truck was less stable on off camber stuff and the gains were minimal. Both guys are planning on going to a 4-link setup next...which is much more involved than most are willing to go and don't believe there is adequate room to do so with the amount of lift most of us run..
Old Oct 16, 2019 | 09:36 AM
The_OGCJR's Avatar
Originally Posted by whowa004
I've spoken with some guys near me running the panhard and said they wouldn't do it again...
Interesting. I could see that....I wonder if custom, extra long sway bar links in the rear would help that? I don't understand suspension geometry enough to know .
Old Oct 16, 2019 | 10:03 AM
whowa004's Avatar
I think the extended watts or a custom extended watts is the way to go unless 4 linking it. No way a panhard with longer sway links is going to outperform an extended watts or be worth the money to do so as the gain would be minimal.
Old Oct 16, 2019 | 10:08 AM
Airborne2016's Avatar
I agree, My father's discovery build has a 6" lift on 33"s. He went with a Panhard at first, then replaced it with rovertyms watts linkage. Driving his disco feels a bit excessive and most likely would result in a disco pancake for what I'm doing nor do I have the amount of expendable cash to copy it.
Old Oct 16, 2019 | 10:17 AM
Jensen Vermont Stenberg's Avatar
I’ve thought the same with the rover and it seems outside of the standard spring/spacer lifts your best bet will be custom fabrication. the aftermarket on these discos isn’t quite what it is for jeeps. I think that a cantilever system would allow you to run long travel shocks without have to cut holes in the cargo area. I am no expert have no experience with this and it looks expensive. Here’s a Jeep with a cantilever setup on the rear axle, looks awesome!
TRIARII
Oct 20, 2018 06:53 AM
lordiasd
Feb 1, 2016 06:38 AM
LRlax11
Dec 16, 2015 02:33 AM
skatelove303
Jun 26, 2009 02:11 PM
ajh
Oct 15, 2007 03:17 PM
