Look at what I found
Old Oct 23, 2010 | 09:08 AM
peanuts8888's Avatar
Default Look at what I found
So, I'm replacing my head gaskets and the top of the cylinder heads are covered with a sludge type substance. Is this normal?
Old Oct 23, 2010 | 09:24 AM
NiteTrain's Avatar
yeah it's normal for engines that don't get regular oil changes every 3-5K miles.
Old Oct 23, 2010 | 10:20 AM
tweakrover's Avatar
is it sludge or is it hardened varnish? That looks pretty normal, and not too bad IMO.
Old Oct 23, 2010 | 10:53 AM
lipadj46's Avatar
It's not really sludge but definitely more than varnish. Be sure you use a HDEO like rotella 5w40 at 5k mile intervals. How did the valve covers look? You may want to drop your oil pan and clean it up and clean up the oil uptake screen. Oh yeah after the job use a cheap dino and change after a week.
Old Oct 23, 2010 | 01:50 PM
MuddMouth's Avatar
Ya that doesnt look that bad really, Ive seen worst.
Old Oct 23, 2010 | 02:54 PM
A couple more photos. Why is it in the intake and only in the front four?
Attached Thumbnails Look at what I found-imag0068.jpg   Look at what I found-imag0067.jpg
Old Oct 23, 2010 | 04:08 PM
Because your PCV sucks the crank case gases out on the valve cover and into the engine to be burned.
If the PCV is located towards the front of the intake then all the oil will collect on the front half.
It turns black like that on the intake because when the engine is hot and the oil vapor hits the hot metal it forms that varnish/sludge.
This is bad...http://www.carbibles.com/sludge_casestudy.html
Old Oct 23, 2010 | 04:16 PM
Ok, got it. It is nothing for me to be overly concerned with but would using an oil catch can be advised? In a earlier post it was recommended to use a "cheap dino". What's that?
Old Oct 23, 2010 | 04:32 PM
lipadj46's Avatar
cheap conventional oil like autozone or walmart 10w30, use it for a week and change to a good oil. This will ensure all the crap from the head gasket job is flushed out.
Old Oct 23, 2010 | 06:03 PM
What he said, along with a cheap oil filter, then switch to a good oil filter like a NAPA (Wix) or a Purolator oil filter and use diesel oil and change it every 5,000 miles.
Not every 6,000, not every 5,500, every 5,000.
bosshogt
Dec 23, 2011 10:24 AM
EricTyrrell
Nov 29, 2011 01:29 PM
Benhamtroll
Dec 21, 2005 06:39 PM
cherrypicker
Aug 5, 2005 12:38 PM
