Loud odd sound when accelerating
Old Feb 20, 2012 | 10:44 AM
thebloody's Avatar
Smile
Originally Posted by LRFTE
thanks for all the advice- and sorry to be a novice but around about where am I supposed to be looking for these fittings? that undercarriage looks all the same to me
You don't have to apologise for being a novice most of us are weekend mechanics (myself included), you had the good sense to research the issue and by doing so saved your self $7k.
Old Feb 20, 2012 | 11:10 AM
discotheque's Avatar
what exactly does the cricket noise sound like? mine has more of a whine at high speeds (happens at around 50mph, stops, and again at around 70mph).
if you get distracted your mind kind of drowns it out, but it can be annoying.
i tried crawling under and looking for the grease nipples but i just have no idea what im looking at. ill have to have someone call me tonight when i get off work, unless someone has real good pictures showing the whole driveshaft..
thx
Old Feb 20, 2012 | 11:29 AM
see this write up in the tech section for pictures. If your front section of drive shaft (goes to front differential) does not have three grease fittings then you need to add them by replacing the universal joints.
Propshaft Rebuild - Land Rover Forums - Land Rover Enthusiast Forum
Old Feb 20, 2012 | 12:59 PM
thebloody's Avatar
thx
The drive shafts start to fail around 80K (mine were bone dry at 84K) so if you haven't rebuilt it you should go ahead and have that done.
Adsan1280
Jan 2, 2013 02:52 PM
MMWnLMD
Oct 7, 2012 08:09 PM
Thatdudeuno1
May 1, 2012 05:10 PM
HelenaRover
Sep 14, 2010 11:43 AM
usmc0341
Aug 18, 2008 11:43 AM
