Low speed vibration/shudder
Old Apr 2, 2013 | 11:25 AM
Domrockstar's Avatar
4wd High
I have my guy looking at it tonight. I will update with what we find. THANKS!
Old Apr 6, 2013 | 10:09 AM
dparham's Avatar
Any news? Ive always had this a little and o rebuilt driveshaft and it is still there mostly when car is cold. . And mostly around 35mph and around 70 ... Accelerating i dont feel it.. Its mostly when cruising at those speeds... Another thing is, if accelerating and letting off gas and accelerating... Sometimes i hear a chklunk but not all the time and not really hard... For some reason the feeling is in pedal and steering wheel slightly shakes but you cant see it... Just feel it... I get a feeling drivers front always feels like a vibration which could be another problem or just a sympathetic vibration? With headlights on, i get the 4 amigos especially when signaling to left.... Strange!
Old Apr 6, 2013 | 03:20 PM
dparham's Avatar
Im replying to my own thread but i think this seems like transfer case but i dont have a reader for drivetrain , anyone close to me who could help? ( west Palm Beach, FL)
Old Apr 8, 2013 | 01:40 AM
FreeRideSLR's Avatar
FYI mine turned out to be cupped tires (treadwright).
Old Apr 8, 2013 | 10:48 AM
4wd High
My mechanic said it could be a bunch of different things, he's most concerned with the rear differential. But because it doesn't happen all the time he couldn't diagnose it yet.
Old Apr 10, 2013 | 07:31 PM
dparham's Avatar
this is totally stupid Im sure but if the rear main seal is leaking can it fill up the bell housing and make it run odd? maybe Ill remove that inspection plate and 3 qts of oil drain out all over the place!? lol then it start running smoother?
Old Apr 11, 2013 | 07:33 AM
drowssap's Avatar
no wouldn't happen "rear main seal is leaking can it fill up the bell housing"
Old Apr 11, 2013 | 07:48 AM
dparham's Avatar
Ok... I didnt think so but havent parted an engine in about 15 years... Lol im starting to wonder ( i know these may seem off) if i have a stopped up Cat (p0430) making it rumble and seem like driveline... I changed all fluids in the major service and all synthetic and all looked ok... I do think i have either a oil pan gasket leak or oil cover, main front seal leak(tightened all valve covers and seems oil on oil pan but not too oily upwards... Some oil behind waterpump or wet grime but no smell of coolant and no puddles oil on ground and ac drippins and drive shaft clean ... One of those or all lol... But i did have a blowout of the passenger side ypipe manifold gasket... Maybe too much pressure from a blocked cat (430 passenger side?) ... And maybe thats why i pull no codes but 430 and engine idle a little rumbly so when driving the slight hesitstiom either confuses tranny or just i feel like its loose when its not? At this point im just guessing but its really P O ing me off lol
bradjohn
Aug 19, 2015 10:59 PM
Optimusglen
Jun 17, 2013 09:23 PM
JakeVT
Mar 26, 2012 08:20 PM
ljdiscovery
May 22, 2010 08:45 AM
elboy0712
Feb 7, 2010 01:18 AM
