Misfire
Old Nov 23, 2007 | 05:00 PM
bomber's Avatar
4th Gear
Default Misfire
I have a 2004 Disco and my wife drives it as her daily driver. So a couple of days ago she ran it low on gas and now the check engine light is on and shows a misfire in 1 and 6 cyinders. To me it felt like maybe some bad gas, so I ran some sea foam through 1/2 of tank of gas and then filled it back up and seems to run better, but still is missing. I did change the plugs after I ran the sea foam through and they were pretty nasty, some were fouled and some were missing electrodes. Any help here would be grateful. Thanks Darin
Old Nov 23, 2007 | 05:03 PM
Default RE: Misfire
How many miles on the truck?
Old Nov 23, 2007 | 05:08 PM
bomber's Avatar
4th Gear
Default RE: Misfire
67,000
Old Nov 23, 2007 | 07:24 PM
Default RE: Misfire
You are most likely looking at new wires, # 6 is a common one to burn out. Might want to consider ordering a set of 8 mm Magnacor wires, about the best you will find for a Rover and half the price of new factory wires.
Old Nov 23, 2007 | 08:09 PM
bomber's Avatar
4th Gear
Default RE: Misfire
I found some for $87.50 from ultrarev.com, that's the best price I could find, unless somebody knows where there is a better deal than that? Anyway thanks for the input and quick response, I'll get those ordered and try them out.
Old Nov 24, 2007 | 09:19 AM
Default RE: Misfire
Are those the 8mm Magnacor or the 7's, it makes a difference, you want the 8's to help with the excessive engine compartment temps.
Old Nov 24, 2007 | 02:42 PM
bomber's Avatar
4th Gear
Default RE: Misfire
They are the 8mm.
Old Nov 24, 2007 | 04:52 PM
Default RE: Misfire
That's a great price, go for it.
Gromeo
Jan 24, 2013 03:41 PM
ta981
Jun 10, 2006 02:15 PM
Scott2747
Feb 8, 2006 12:11 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
tbesselman
Jun 1, 2005 01:54 PM
