More amigo woes. Repeatable issue.
Old Jan 11, 2025 | 09:26 PM
disco96sd's Avatar
pull the dash and take out the warning lights
Old Jan 11, 2025 | 11:54 PM
Richard Gallant's Avatar
@cappedup first of ignore @disco96sd hiding lights is not even a good ha ha suggestion a lot of buyers have been screwed over by that crap
If you look behind each tire you will see a yellow connector that is the ABS speed sensor connection, pull it apart make sure the connection are tight and clean then put it back together. You could add a BIT of electrical conductivity grease just to the lower 3rd of each of the metal pins.
While you are at jack the tire up and check your wheel hub, you will have to look it up but there it just requires moving the tire around and feeling for "looseness"
Finally visually inspect your brake pads for damage other issues
Some code readers can display the data but rough road is generally a loose connector/Frayed wire/failing sensor in the hub
ChamosLR3
Oct 5, 2021 07:13 PM
JohnP38
Range Rover P38 (2nd Gen)
Jul 8, 2021 12:21 PM
mln01
Nov 27, 2020 01:19 PM
WarrenZ
Sep 9, 2020 09:36 PM
Jared9220
Sep 21, 2012 01:21 PM
