Is my WATER PUMP bad?
Old Jun 6, 2014 | 07:51 AM
  #61
RicketyTick's Avatar
Originally Posted by masterseung
It's either the block or the head... not sure if there is any way to tell..
Yep, looking for an engine..
You'll probably have to tear it down and carry to a machine shop to check pressure test everything.
Old Jun 6, 2014 | 11:42 AM
  #62
masterseung's Avatar
Lot more than I bargained for...
Old Jun 6, 2014 | 04:04 PM
  #63
How do you know for sure it's not a head gasket?
Old Jun 6, 2014 | 05:39 PM
  #64
Not sure but head gasket was already done
Old Jun 7, 2014 | 09:24 AM
  #65
The head gasket was changed 1k miles ago..
I'm guessing, block cracked behind cylinder sleeve, cracked head, head wasn't properly skimmed and head gasket gave out again due to head being warped. Just thoughts and just trying to help but, have you removed the plugs in 3 & 5 to see if you have water in those cylinders or steam cleaned pistons? I had a misfire on #7 and when I removed the plug and turned the engine over it sprayed water everywhere but, I suspect mine was more sudden than yours. Mine was all at once with no small leaks.
DiscoTanB
Aug 13, 2015 08:10 AM
dswilly
Oct 15, 2012 12:28 AM
zracin
Nov 3, 2011 12:17 PM
Savannah Buzz
Jul 21, 2011 08:02 PM
imnothans
Nov 30, 2009 07:53 PM
