Need Everyone's Input! Engine sounds
Looks like a 2004 G4 you're looking at?
Did you check the oil fill cap for any signs of a head gasket leak? How's the coolant level?
Can you get a better video of the truck after it's warmed up? Preferably pointed into the engine compartment or closer to the engine? It sounds like a slipped liner to me based on what I've heard them sound like before but I could be wrong.
Top Hat block: https://robisonservice.blogspot.com/...and-rover.html
Slipped liner probably isn't cheap if you're not doing it yourself.
How bad is the rot? Any pics?
I bought a truck with a ton of rust underneath. I had it sandblasted and it wasn't as bad as I thought. It's not a perfect frame but I re-coated it and it's good now.
From Pittsburgh that's a summer project. From the south east thats parked in the field and used for spare parts.
I likely know someone with an 03 frame you could get for a decent price.
Nonzero but very low. The lifters only tick when oil pressure is low, usually due to either a cracked oil pump or walked cam bearing.
