Need Everyone's Input! Engine sounds
Old Mar 11, 2026 | 06:09 PM
specops1526's Avatar
Looks like a 2004 G4 you're looking at?
Did you check the oil fill cap for any signs of a head gasket leak? How's the coolant level?
Can you get a better video of the truck after it's warmed up? Preferably pointed into the engine compartment or closer to the engine? It sounds like a slipped liner to me based on what I've heard them sound like before but I could be wrong.
Top Hat block: https://robisonservice.blogspot.com/...and-rover.html
Old Mar 11, 2026 | 07:12 PM
Aj6543's Avatar
If it’s a slipper liner, then it’s an expensive repair?
I think this car is total dud. The chassis has structural rot. So double whammy.
Old Mar 11, 2026 | 11:59 PM
PickleRick's Avatar
If it has rot/rust on the frame run away as fast as possible. unless it's a CDL model or has a super clean body/interior and you're getting it for parts rig pricing.
Old Mar 12, 2026 | 12:41 PM
Slipped liner probably isn't cheap if you're not doing it yourself.
How bad is the rot? Any pics?
I bought a truck with a ton of rust underneath. I had it sandblasted and it wasn't as bad as I thought. It's not a perfect frame but I re-coated it and it's good now.
Old Mar 12, 2026 | 04:40 PM
Aj6543's Avatar
Old Mar 12, 2026 | 05:44 PM
Extinct's Avatar
Fixable but will scare off a lot of buyers
Old Mar 12, 2026 | 06:01 PM
PickleRick's Avatar
From Pittsburgh that's a summer project. From the south east thats parked in the field and used for spare parts.
I likely know someone with an 03 frame you could get for a decent price.
Old Mar 13, 2026 | 03:11 PM
Aj6543's Avatar
What are the odds the ticking sound is Ticking Lifters?
Old Mar 13, 2026 | 07:46 PM
Extinct's Avatar
Nonzero but very low. The lifters only tick when oil pressure is low, usually due to either a cracked oil pump or walked cam bearing.
Old Mar 13, 2026 | 07:57 PM
Aj6543's Avatar
The engine sounded exactly like this video. More audible ticking at the end.
this guy says he thinks it was the lifters.
evil_goat
Jul 9, 2024 12:00 PM
Ljay
Apr 30, 2023 06:46 PM
KlamathMatt
Oct 23, 2013 04:53 PM
Rover82
Sep 19, 2008 01:24 AM
StephenK1706
Apr 27, 2005 10:17 PM
