Need help // noise coming from under with video...
Old Jan 12, 2021 | 07:53 PM
  #31
SundayFunday's Avatar
That is shaft extension grease zerk.
it’s the u-joints you should want to be able to grease.
Old Jan 12, 2021 | 07:57 PM
  #32
Extinct's Avatar
https://www.roverparts.com/Instructi...TVB000110A.pdf
Old Jan 12, 2021 | 09:18 PM
  #33
GoRoll's Avatar
Update!
Shake and noise is gone after installing the new shaft. Drove the car for 10+ miles.
I’ll grease it tomorrow and still change all tee diff and tranny fluids.
Thanks everyone.
Old Jan 13, 2021 | 02:48 AM
  #34
The Deputy's Avatar
Good news, but l wouldn't stop there. Still change axle(s), transfer case and trans fluid. Trans fluid and filter is a somewhat different process than most, so read up on changing before you tackle. Also, you should have a grease zert on the front joint of the rear shaft, grease that also.
Old Jan 13, 2021 | 03:10 PM
  #35
GoRoll's Avatar
That’s my next step. I ordered all of it.
i could’ve bought it elsewhere for cheaper but AB gives us so much information of how to that we need to support these guys.
Old Jan 15, 2021 | 07:27 PM
  #36
GoRoll's Avatar
wasn't too bad.
I didn't have a 1/2 ratchet and took me 2-3 hours trying to figure out how to take off the transfer case nut to refill the fluid. My breaker bar wasn't cutting it since the exhaust or e-brake line was on the way.
Finally went to buy a 1/2 ratchet.
Also, how many qt does the transmission take? Atlantic British sent me 6 qt of oil but after 2, it started dripping like crazy...
(I also lost my key so I couldn't start it, I got spare that's coming tomorrow)
Old Jan 15, 2021 | 09:23 PM
  #37
Dave03S's Avatar
Your are supposed to fill the tranny with the engine running or you won't be able to get those six quarts in it. You might want to look up the exact procedure.
Old Jan 15, 2021 | 10:03 PM
  #38
GoRoll's Avatar
i was going to start it after the 2 quarts but I'll do it tomorrow. I lost my keys.
Old Jan 16, 2021 | 10:42 AM
  #39
The Deputy's Avatar
Yes, should take another 3.5/4 quarts...after starting and running shifter through gears (with foot on brake or parking brake applied). Make sure you are on a level surface.
Old Jan 16, 2021 | 02:08 PM
  #40
GoRoll's Avatar
Thanks Guys... I was able to add total of 5.5 or so.
Maybe it's mental but the truck is so much quieter and drives super smooth.
I'll be ordering rear drive shaft soon.
Brandon318
Feb 17, 2020 03:05 PM
cobbcj7
Oct 29, 2018 01:15 PM
cammyr01
Apr 15, 2015 02:16 PM
sfidelisrp
Oct 8, 2014 07:02 AM
MichiganRover
Jan 21, 2013 12:12 PM
