Need suggestions on how to remove old water pump gasket material
Old Jan 3, 2019 | 12:41 AM
bcolins's Avatar
Default Need suggestions on how to remove old water pump gasket material
My D2 has been down for several months, waiting for me to find time to replace the water pump. I finally got around to it Monday,...….I've done this a few times on other prior D2s,....but never had this much trouble with the old pump gaskets. I have pulled and prodded and tried back scraping with a razor blade,....as recommended by Atlantic British in their water pump video,.....but that old gasket material is truly on there. I've been able to remove about 1/3 of it by just pulling the overhanging edges,....but in the other areas, without that overhanging edge,....its not moving. I tried slipping a razor blade under it,....and was able to lift a few short bits,....but the remaining half to 2/3s of it is not moving.
Hate to get too aggressive with a razor blade since it's aluminum,....and don't want to damage the gasket surface.
Wondering if there is a chemical gasket remover that will really lift a thick gasket like this one.
Any suggestions from those who had encountered this reluctant water pump gasket problem??
Brian in San Antonio
Old Jan 3, 2019 | 06:20 AM
The Deputy's Avatar
Old Jan 3, 2019 | 07:32 AM
JUKE179r's Avatar
I wouldn't recommend oven cleaner spray on aluminum if anyone says to do it.
Old Jan 3, 2019 | 08:56 AM
OverRover's Avatar
Permatex 80645 from any auto parts store.
> https://www.permatex.com/products/ga...w-voc-formula/
Or spray CRC 05021.
> https://www.crcindustries.com/produc...-oz-05021.html
Old Jan 3, 2019 | 09:24 AM
Wesley Lueders's Avatar
I used a razor blade at a 90 degree angle to ensure I didn't gouge or deform the aluminum mating surface.
Old Jan 3, 2019 | 09:41 AM
Friday Night Disco's Avatar
I used a razor blade to get the easy pieces and then a combination of scot brite pad and a dremmel with a polishing wheel
Old Jan 3, 2019 | 10:42 AM
Best4x4's Avatar
They used to sell a spray that dissolved paper gaskets. I haven’t seen it lately, but you just sprayed it onto the paper gasket, waited like 5min & then it just basically fell off with a razor blade.
Old Jan 3, 2019 | 10:54 AM
abran's Avatar
I use a dull putty knife
Old Jan 3, 2019 | 11:14 AM
jamestfl's Avatar
A plastic version of the razor blade, brake cleaner, blue scotch brite and elbow grease. Figured gouging would be a particularly bad idea near the water pump.
Old Jan 3, 2019 | 04:58 PM
Big Jim Swade's Avatar
I was in the same boat a couple of years back when I changed my water pump. It really takes a long time to get the old gasket off. I used a razor blade and scotch bright pad. I tried the Permatex gasket remover, but it didn't seem to do much.
BS50MGSXR
Dec 5, 2016 11:13 PM
Colorado David
May 28, 2013 07:05 AM
Travelor
Dec 29, 2011 03:39 PM
willrok13
Jan 1, 2011 03:44 PM
myall200
Nov 23, 2008 10:39 PM
