New Ball Joints Squeeking, Should I Be Worried?
Old Jul 7, 2018 | 06:13 PM
TaylorCadence's Avatar
Originally Posted by abran
Yeah, forgot to comment on the loosening part.
also if I’m correct you did 100 instead of 80, no big deal. That 20 pounds won’t kill it
just figured it would be a big deal. Read other threads that guys had to replace ball joints within a year due to incorrect values and installation. Don’t want that to happen so I just gotta man up and redo em
Old Jul 7, 2018 | 10:24 PM
abran's Avatar
Like I said, a lot easier and almost fun the second time.
Old Jul 8, 2018 | 02:38 PM
Another thing I did as suggested from another thread was to put non seizing grease in the seats of the ball joints. Bad idea = squeeking?
Just didn’t want to go trough the nightmare of trying to break them loose again next time I didn’t he job.
Old Jul 8, 2018 | 02:52 PM
abran's Avatar
if they are in there tight, the grease would have no effect.
Old Jul 8, 2018 | 02:54 PM
The Deputy's Avatar
No, that is a good idea. Anti-seize will make it easier to disassemble. Once those ball-joints are pressed into place, there should be no movement of ball-joint housing. They did press in tightly, right?
Brian.
Old Jul 8, 2018 | 04:30 PM
Brian.
oh heck yeah they did. I’m jut a little on edge now becasue the more I reseat/press them in the wider the boring will be in the knuckles. RAVE states they’re only good for three uses. I will know right away when I redo them but may have to swap the knuckles off my parts rover too which means disassembling and pressing out those old joints... it’s never ending
Old Jul 8, 2018 | 05:16 PM
The Deputy's Avatar
Best case scenario would be...a couple round trip tickets to Hawaii for a couple members here to help you out.
Brian.
Old Jul 8, 2018 | 06:30 PM
Brian.
You guys make my rover new again and consider it done haha
Old Jul 10, 2018 | 04:40 PM
Miraculously enough the joints stopped squeeking and causing resistance! Gave it a few days as suggested. Still going to swap the tops out but thought everyone should know who may also be nervous about tight ball joints. I’ve got RN steering rods coming in today and alignment/ ballance soon after that. Front end is looking up!
Old Jul 10, 2018 | 06:49 PM
abran's Avatar
I didn't catch that stiffness was also an issue, usually takes a few days to loosen up. as you have observed!
Codyt
Oct 16, 2018 10:31 AM
Aj6543
May 9, 2018 02:47 PM
JettsRover
Nov 2, 2017 01:59 PM
evansjoem
Nov 12, 2013 12:21 PM
jrm123180
Feb 5, 2011 12:03 PM
