New power steering pump - does this gasket look right to you?
Old Jan 26, 2026 | 02:58 PM
Brandon318's Avatar
Default New power steering pump - does this gasket look right to you?
First thing I noticed was how out of place this gasket appears. Haven't ever noticed this on the half a dozen other pumps I've installed on these. Specifically clocking that plastic bit.
Old Jan 26, 2026 | 04:46 PM
Extinct's Avatar
Yep, that is the new upgraded one. You can check the bolts for tightness but don't overtighten or you will crack the rear cover. When you install it, connect the hoses and let it sit for a few hours before mounting to see if it leaks. I put some of the blue shop towels under mine to see if it leaks.
Old Jan 26, 2026 | 04:49 PM
Brandon318's Avatar
How does that gasket work? It looks like adhesive on one side, which makes sense, but slick plastic on the other mating surface?
Old Jan 26, 2026 | 04:51 PM
Extinct's Avatar
Yeah, it is a mylar gasket with a silicone coating for sealing. Not sure why they use mylar, probably because it is impervious to ps fluid.
Old Jan 28, 2026 | 07:39 AM
nashvegas's Avatar
New or improved or whatever, that’s utter ****ing garbage from a QC standpoint from a parts manufacturer.
Old Jan 28, 2026 | 08:55 AM
Brandon318's Avatar
$250 for this fine piece of craftsmanship 🙃
Now let's put $70 worth of fluid in there and see if it works!
Triddell62
Apr 22, 2020 11:08 AM
vandal996
Dec 15, 2013 06:23 AM
cobbcj7
Dec 5, 2011 06:26 PM
vandal996
Feb 1, 2011 07:02 AM
