New trouble
Old Jan 23, 2013 | 06:47 PM
roverich's Avatar
Default New trouble
So after putting the lift and tires on my D2 , a week later the truck is making some new noises ..Started out as a squeaking from the left front , kind of louder when taking a right turn .Sounded like a wheel bearing so i got a used hub and replaced it , Squeaking went away for a day , came back again ..front Drive shaft was original so i replaced it . Now the squeaking is gone and you can feel a little clicking sound when you start rolling and it turns into a roar / vibration when you get up to speed . back shaft is all right as is the rotoflex coupling . truck is parked for now and it is not getting driven until i can figure it out..Could this be a CV joint issue ? Help please ...Thanks in advance..
Old Jan 24, 2013 | 09:14 AM
SuperSport's Avatar
Maybe pull the front drive shaft and drive without it and see if it goes away. Could be something wrong with replacement?
Old Jan 24, 2013 | 09:47 AM
ZGPhoto's Avatar
I'd probably suggest locking the center diff before driving without the front driveshaft...
Old Jan 24, 2013 | 10:45 AM
antichrist's Avatar
Does the clicking change when turning sharp right or left?
Old Jan 24, 2013 | 12:11 PM
SuperSport's Avatar
Hehe, yep.
Old Jan 24, 2013 | 05:52 PM
roverich's Avatar
So i need to check if the sound happens when turning sharp left and right and then remove the front prop shaft and see if the problem goes away ...OK . i will try this..As far as i know the replacement drive shaft is OK . No play in the U joints what so ever...
Old Jan 24, 2013 | 07:01 PM
jfall's Avatar
Well, the D2 has classic CV joints in it - just like any run of the mill front wheel drive car.
Maybe those need grease or replaced?
Are your CV boots ripped?
jfall's Avatar
Actually, the D1 is better in that respect.
No CV boots.
Seems more rugged.
Old Jan 25, 2013 | 06:33 PM
roverich's Avatar
No rips or tears . Gonna have a lift to use tomorrow .
Old Jan 26, 2013 | 04:55 PM
roverich's Avatar
You nailed it ..Bad replacement shaft..Tried a used one from a buddys bone yard of discos and sure enough that was it.. Replaced it with a servicable front shaft from AB and sure enough , sound went away...
Thanks for the help guys , much appreciated ...
Matt_Attack352
Jan 13, 2014 09:55 AM
SeanLeMay
Apr 29, 2013 12:18 AM
mossmanxjt
Jun 22, 2012 03:25 PM
michrobe
Jan 18, 2009 11:02 AM
OlDood
Jun 24, 2007 07:47 PM
