No forward gears only reverse
Hmm, next thing i'd probably do is to get the tcase in low, switch on the M mode unplug the transmission harness plug and switch the gears and check if you are getting voltage on the pins corresponding to solenoids. This will require getting all four wheels off the ground. If you are getting current on the pins then test the resistance on solenoids (by measurnig across pins in the socket), if that is ok then i'd proceed with test in my previous post.
I got a multimeter running at between 14.11 to 14.24 also just replaced xyz switch still no forward gears
danth0ny
Sep 7, 2024 02:18 PM
