No forward gears only reverse
Old Dec 18, 2023 | 03:36 PM
  #21
ONeil64's Avatar
Originally Posted by miron
Hmm, next thing i'd probably do is to get the tcase in low, switch on the M mode unplug the transmission harness plug and switch the gears and check if you are getting voltage on the pins corresponding to solenoids. This will require getting all four wheels off the ground. If you are getting current on the pins then test the resistance on solenoids (by measurnig across pins in the socket), if that is ok then i'd proceed with test in my previous post.
today it’s pouring out and all the ice was gone so when I got home from work I tried to put the transfer case in low and use Manuel to go forward. Nothing in 3, 2, or 1 so I utilized only having reverse to move the car out of the way. My first day of vacation on Wednesday I’m gonna swap the battery with a newer one I just got for my suburban. See if it’s voltage issues if not looks like I’m gonna have to tear apart the transmission right
Old Dec 18, 2023 | 04:40 PM
  #22
Harvlr's Avatar
Have you checked your voltage?
Old Dec 18, 2023 | 04:42 PM
  #23
ONeil64's Avatar
I don’t have a voltage reader so I’ll just swap it with a brand new battery
Old Dec 18, 2023 | 05:04 PM
  #24
jastutte's Avatar
get an UltraGauge. you can monitor voltage, amongst many other things, with it.
Old Dec 18, 2023 | 05:10 PM
  #25
Harvlr's Avatar
And you can buy a cheap multi meter for under $20
Old Jan 5, 2024 | 10:53 AM
  #26
ONeil64's Avatar
I got a multimeter running at between 14.11 to 14.24 also just replaced xyz switch still no forward gears
Old Sep 5, 2024 | 02:37 PM
  #27
Broken08's Avatar
Same problem. Did you find a solution?
Old Sep 5, 2024 | 06:04 PM
  #28
Extinct's Avatar
Typical ZF failure mode on D2 is failed forward clutch, trans has to come out to fix. Probably a good idea to get a good used one and just swap.
danth0ny
Sep 7, 2024 02:18 PM
DHTaylor
Nov 18, 2022 12:11 PM
Papag1313
Nov 12, 2019 07:27 AM
Gromeo
Jan 11, 2017 11:39 AM
ValveCoverGasket
Oct 26, 2011 04:30 PM
