no start m and s lights flash good spark, starting fluid wont even fire
#21
Thank you. I will do that. I didn't realize the pump might shut off if pressure is achieved. Most European cars don't have a mechanism for that. They simply run the pump constantly and return all the fuel that pushes past the regulator. I'm going to lift up the rail tonight to insure i'm getting proper fuel volume
#22
#23
Fuel "volume" or not, I think if you have 50 psi will cranking, the engine should at least start? Back when you said it started with the plenium off, are you sure you dont have an air intake issue? maybe something blocked in the air box? Hmm.. maybe a rag sucked in somewhere? Seen it before
01disco2SE
07-29-2013 11:49 AM
