A note on bleeding
Old Jul 12, 2020 | 03:06 PM
Richard Gallant's Avatar
Default A note on bleeding
This may help someone else who is having troubles bleeding
  • The screw the T has a slot in it, when you get ready to bleed do not remove the screw simply take out about 2 or 3 turns
  • Now lift your expansion tank - cap off
  • You will hear the air hissing out keep the tank in the air until the hissing stops and AF flows
  • With the tank in the air tighten the screw back down - I can do solo but apparently have longeish arms
  • Top up the tank.
There is a lot less AF loss and very positive indication you are getting air out.
Old Jul 12, 2020 | 04:56 PM
whowa004's Avatar
this works super well. I've never had any issues bleeding my coolant system in this vehicle..
Old Jul 13, 2020 | 07:53 AM
boston4's Avatar
this is a good suggestion - many people recommend trying to fill through the bleed hole which is just crazy. Personally I use the following method so that I don’t need to bother lifting the reservoir out of place:
Remove the bleed screw and uncap the reservoir. Then, pull the upper hose out of the molding on the fan shroud. Squeeze the hose with your hand to push air out of the bleed screw, then put your finger on top of the bleed screw and release the hose - the system will suck coolant in from the reservoir. Repeat until coolant is topped up.
Old Jul 13, 2020 | 12:53 PM
NewToTheTwo's Avatar
I slide a piece of wood under the expansion tank so it rests on it and I can do everything I need to do without having to hold it.
I think I used a 2x3 - between the fuse box and valve cover.
Brandon318
Nov 5, 2019 01:57 PM
Brandon318
May 29, 2019 06:39 AM
joshrave
Mar 19, 2015 11:35 PM
AdrenalinPlease
Jan 7, 2013 06:53 PM
grandkodiak
Aug 2, 2012 11:14 AM
