off road level switch wiring
Old Jan 15, 2020 | 06:31 PM
mikefitz's Avatar
5th Gear
Default off road level switch wiring
I have a '99 D2 V8. I'm putting the dash back in. At the off road level switch (YUF101751) I have two green plugs that fit. I think one is for the front window heater, which I don't have, and the other is for the height switch.
Both the green plugs fit and both have a pink and a red wire. One has a green wire and the other has a purple wire. My question is which one to use? (I'm thinking the green wire)
I can't test this as I also have the height switch disabled in the BCU after a spring lift.
Old Jan 15, 2020 | 06:38 PM
Llamasayswhat's Avatar
If you have the switch disabled why even worry about it? plug either one in, or neither.
Old Jan 15, 2020 | 08:04 PM
mikefitz's Avatar
5th Gear
This is obvious. Can you actually help?
Old Jan 15, 2020 | 09:41 PM
mollusc's Avatar
The D2 electrical library (p 4.68) says that the off-road mode switch is connected to a black wire, and (if I'm reading correctly) a purple/pink wire. No mention of anything green or red. I will try to remember to check what's connected to the switch on my parts truck.
Old Jan 16, 2020 | 03:24 AM
mikefitz's Avatar
5th Gear
C0893 off road level
I found it in a rave manual, purple, red, black.
Old Jan 16, 2020 | 03:38 AM
mikefitz's Avatar
5th Gear
I had a closer look, the photo I took wasn't good enough. Then I found it in a rave manual. It is C00893. Pink, red, black
Thank you for your help.
Old Jan 16, 2020 | 02:18 PM
I feel like I provided all the help that is relevant!
"Help, I removed a component from my car, but I still want to plug in the non-working, unneeded connector. What do i do?"
Don't plug it in
JettsRover
Mar 21, 2018 12:21 PM
xathor
Sep 15, 2015 12:08 PM
landy_ala
Jun 16, 2015 09:57 PM
ktm_525
Sep 4, 2012 10:43 AM
MarvelVT
Apr 20, 2009 06:48 PM
