parasitic battery drain
I have/had a parasitic drain and a bad xyz switch pulled, cleaned and replaced the xyz solved the m/s problem, but I didn't have a working meter before the fix. I am now showing .8 with the meter set to ten amps what should the normal reading be? thanks.
Tim 2004 disco
Tim 2004 disco
Put a little light bulb in series with the battery.
put the light bulb out and up high.
Then start to pull fuses - one by one until you get the light to go out.
That will get you to the circuit.
The culprit usually is ..
ready for this?
People putting in after market radios, amps and all that boom boom stuff.
Look for extra wiring going back to the overpriced made in China aftermarket crap. Oh I mean valued accessories.
Rap is not good if it drains the battery.
ready for this?
Dopey
07-22-2007 07:09 PM
