parasitic battery drain
Old Sep 3, 2013 | 08:15 AM
erietim's Avatar
Default parasitic battery drain
I have/had a parasitic drain and a bad xyz switch pulled, cleaned and replaced the xyz solved the m/s problem, but I didn't have a working meter before the fix. I am now showing .8 with the meter set to ten amps what should the normal reading be? thanks.
Tim 2004 disco
Old Sep 3, 2013 | 04:26 PM
0.8 amps would be a high drain in the key off state. 800 milliamps. More usual for under 100 miiliamp (.1 amp). You can unplug fuses 1 by 1 to see when it changes. When doing this place something to hold down the hood alarm switch.
Old Sep 3, 2013 | 11:09 PM
erietim's Avatar
thanks savannah I will play with it tomorrow while awaiting power steering pump
Old Sep 4, 2013 | 01:46 PM
jfall's Avatar
Put a little light bulb in series with the battery.
put the light bulb out and up high.
Then start to pull fuses - one by one until you get the light to go out.
That will get you to the circuit.
The culprit usually is ..
ready for this?
People putting in after market radios, amps and all that boom boom stuff.
Look for extra wiring going back to the overpriced made in China aftermarket crap. Oh I mean valued accessories.
Rap is not good if it drains the battery.
roar huge
Feb 25, 2022 01:31 PM
addeible
Aug 14, 2014 11:13 AM
Windmill.lr3
Mar 31, 2014 03:57 AM
lrjon
Dec 24, 2013 09:56 AM
Dopey
Jul 22, 2007 07:09 PM
