The passenger side window tilts towards the front of the truck when going up gets stu
Old Nov 10, 2011 | 07:18 PM
aarongregor's Avatar
Default The passenger side window tilts towards the front of the truck when going up gets stu
If the regulator is damaged would it cause the glass to have play in it?
Old Nov 10, 2011 | 08:04 PM
If you include the rollers as part of the regulator, yes. Small plastic rollers frequently crack and may allow glass to slip off track.
Old Nov 10, 2011 | 10:03 PM
boris_gti's Avatar
The small white roller is what happened to me. The window will want to tip towards the front of the truck and it will want to get stuck. After I took the door panel off and inspected everything, I found the little white wheel to be cracked.
I took the broken wheel to Home Depot and found that a similar wheel is used on shower doors (rolling style). I bought the little bugger, took it home and had to grind the overall thickness if I remember correctly. After that I used a bolt with a nut on the other side and I remember I had to use appoxy to hold the nut on the bolt because it would wanna come loose. I can't remember all the details but I remember buying the roller from Home Depot and making it work. This was done 2 years ago and it still works like new.
Hope this helps.
Cheers!
Old Nov 10, 2011 | 10:09 PM
And here is another HD solution, a solid teflon piece that replaces the roller and moves in the track, mine have been working for just about a year. You can also buy fabricated plastic rollers, and machined metal rollers.
https://landroverforums.com/forum/di...ight=regulator
Old Nov 10, 2011 | 10:27 PM
Awesome fix to both of you, I just had that door apart checking the actuator and put it back together today...UGH!!! I replaced the regulator a few years back on my drivers side when someone broke the window to steal my GPS but I forget...Do I have to remove the regulator to get the glass out to remove the wheels to repair it? Savannah I like the square pieces you fabricated, if I cant find them I will do what boris did.
Old Nov 11, 2011 | 05:08 AM
both come from same store. squres are in the hardware asile with feet on pads for furniture. I just had to remove the channels of the regulator, they have some sort of slotted screw mount. Did not have to take out glass.
Old Nov 11, 2011 | 06:50 AM
boris_gti's Avatar
Same here....glass was left in. Actually if I remember correctly, regulator stayed in as well. I was able to remove the wheel and put it back in without removing anything else.
Old Nov 11, 2011 | 06:00 PM
Cool, thanks guys big help. Im doing the ABS mod this weekend so mid week I'm going to Home Depot...Ill post which option I end up doing. Thanks again to both of you.
Crash458
Aug 5, 2014 05:40 PM
Gerard
May 27, 2011 09:57 AM
bamarover13
Jan 25, 2010 10:53 PM
roverohio
May 22, 2009 11:17 PM
bcolins
Oct 2, 2008 12:36 PM
