Pin/Actuator in Brake Booster Came Out!!!
Code first.
P1590 ABS rough road signal circuit malfunction Hardware is OK, but SLABS ECU is sending an error signal ( from RAVE).
I would suggest you go find a steep hill and try the Hill Descent Control. If that works, you know the ABS is functional. Procedures for engaging are in the owners manual. See what happens (safely of course) and re-bleed.
