Power Steering Pump Rebuild Video Link
Old May 25, 2018 | 05:00 PM
TaylorCadence's Avatar
Default Power Steering Pump Rebuild Video Link
For all of you rebuilding your own power steering pumps at home, here's a video. It's not perfect but it explains how to rebuild a Discovery 2 pump step by step including links to various products I used.
Important: Please read description on YouTube first before watching. There are a couple steps I missed during the initial take. Enjoy.
Old May 26, 2018 | 07:53 PM
Roby466's Avatar
Nice video! I just did mine a few days ago and I can't get it to work right.. It appears like there is air in the system but regardless how often or when I bleed it, no air comes out. Is yours working fine? Did you get your kit from ebay?
Cheers
David
Old May 26, 2018 | 09:23 PM
Cheers
David
thanks!
havnt installed yet. Doing it tomrw... any prominent noises? Is there binding? how can you tell it’s not working right. Mine is from eBay yes.
Old May 27, 2018 | 08:11 AM
Roby466's Avatar
It was a bit hard to turn after the rebuild but that’s apparently normal. I just spoke to the ebay seller and he said if the pump ran dry it moght have burnt itself. As I started the car and ran it to 2500rpm for 25 mins it’s possible I burnt it... make sure there is oil in your pump before starting the truck. Maybe connect the inlet but not outlet, fill the reservoir and turn the pump by hand until it leaks out the pressure side, then connect everything and start the truck.
I’m ordering another kit and will do that when I start it up.
It works now but it sounds like there is air in the system. No air comes out the bleed home. I hear the pump whine a bit and there is barely any assist at idle. PAS works fine at speed but is noisy.
Good luck with yours!!
David
joshjellel
Feb 16, 2015 10:53 AM
04duxlr
Jan 30, 2014 10:20 AM
vandal996
Dec 15, 2013 06:23 AM
vandal996
Feb 1, 2011 07:02 AM
