priming oil pump
Google priming LS1, there are several methods of priming. Its actually a good bit easier on the Disco, you can screw a fitting in to the oil filter housing with a hose attached and either gravity fill or pressure fill from there.
I’ve packed em with vaseline and never had an issue. You “should” technically be able to coat the oil pump gears in oil, close it all up & upon startup within 10sec have oil pressure.
did you replace the pump with a used pump? The pump and cover wear together and have a very very fine tolerance. Transferring old pumps into old covers always feels like bad juju to me. Did you check the cover carefully? Any scoring or wear? How about the "new" pump?
You still havent answered as to what is actually happening. Are you having a low oil light? Clattering lifters? Did you check oil pressure with a gauge? Flying blind here..
