pulling the T case today
Old Mar 21, 2014 | 07:17 AM
drowssap's Avatar
Savannah, had i nice pic someone has take an extra inspection plate mounted it on a floor jack
Old Mar 21, 2014 | 05:14 PM
FlyingZebra34's Avatar
Well I'm going to try to replace the bearing with the t-case in the truck. Waiting on my buddy to get here with the gear puller for the flange.
Also beyond all reasonable doubt, the nut on both sides of the t-case is 29mm
Old Mar 21, 2014 | 08:15 PM
Ok I have the flange, seal, and snap ring off. I read that this shaft with the bearing should just come out. I have both the tranny and t-case in neutral.
Is this not true or is there more to it?
Old Mar 26, 2014 | 03:02 AM
First Update, I found this lovely thing that is a little bit more specific than the RAVE
http://www.landroverresource.com/doc...Box_Manual.pdf
Second, turns out the bearing was ok. My transmission mounts were destroyed (despite being like 1 year old) and are most likely causing the vibration.
Third, the good news is I didn't have to pull the T-Box to replace the front output seal and the inspection plate seal.
Right now I have a nasty leak coming from the inspection plate for the CDL and with the way it is installed, I don't think I can get the bolts off with the transmission where it is. Might still need to drop the box.
Old Mar 26, 2014 | 05:14 AM
jfall's Avatar
Or use a car floor jack with wheels?
Like for putting in a transmission?
erick846
May 14, 2020 12:55 PM
White Rover
Oct 15, 2013 02:36 PM
sloppyjoe
May 15, 2011 02:29 PM
jwood700
Nov 21, 2009 10:26 AM
shawn
Oct 22, 2007 06:42 PM
