Rear axle breather removal
Old Jun 23, 2010 | 09:11 PM
  #21
Originally Posted by Willie00d2
I pulled my breather out of the rearend. You might have to push the red piece in while pulling the tube. That kit from AB that Spike mentioned is a good idea.
Willie
I do not know if that kit will fit a DII or not.
We might need someone to bite the bullet and try it.
Old Jun 23, 2010 | 10:11 PM
  #22
lordmorpheus's Avatar
Willie, that is right on the money. I found out about the red retaining piece earlier today, and was going to post this link: http://forums.lr4x4.com/index.php?showtopic=44465 tonight after my daughter's Chuck E Cheese birthday party.
Well, this will keep my wife's camera grease free this weekend. This is basically what I was planning to do, except terminate the breather in the engine bay. http://www.discovery2.co.uk/breathers.html
I don't know if the AB breather kit would fit a DII either. I know the metal valve piece would just have to be discarded. I'm just going to have a try with icemaker line this weekend, and will report how that goes.
Old Jun 24, 2010 | 02:42 PM
  #23
Willie00d2's Avatar
McMaster sells tubing. They also have push in fittings. It looks like they use 6mm. I will be doing mine soon too. My front breather is broken off at the housing.
Willie
http://www.mcmaster.com/#tubing/=7oate6
Old Jun 24, 2010 | 08:33 PM
  #24
I'm going to try some 1/4" icemaker hose I picked up at the local Lowes. I know the OEM hose is 6mm, but seeing as the 1/4" is only .01" or .25mm larger than the 6mm OEM.... I can use some emery cloth on the axle end of the tubing.
caymandrew
May 20, 2015 04:00 PM
Praboh
Mar 19, 2015 08:03 PM
TripleThreat
Jan 2, 2015 02:01 PM
cationmoted
Oct 19, 2012 07:39 AM
mherson
Oct 29, 2009 10:54 PM
