Rear Hubs
was joking, btw.
I buy hubs on the scavenger market....6 used = 1 new.
proline = $300ish HUB ASSEMBLY FRONT WITH SENSOR DISCOVERY II, PLD676, TAY100060 - Rovers North - Classic Land Rover Parts
oe = $500ish...unless you get lucky..1999-2004 Land Rover Discovery Wheel Hub Assembly - Driveshaft & Axle - Timken, Front 99-04 Discovery Wheel Hub Assembly - 278-01173417 - PartsGeek
I bought the cheapos from autopartswarehouse.com. No complaints yet. Also, find some coupons and you will get them for ~$100 delivered.
Replacement REPL283708 Wheel Hub | Auto Parts Warehouse
Tip: The front and back hubs are the same, except the wire for the front hub is longer. Buy a front hub and just cut the clips off (don't cut the wires) and zip tie the wires into a nice loop out of the way to use on the back.
Tay100050e-Tay100050e Manufacturers, Suppliers and Exporters on Alibaba.comWheel Parts
Replacement parts are funny. I usually go cheap when I am buying replacement parts. Sometimes it works out, sometimes it doesn't. The thrifty part of my brain says "why pay more, when paying more is not a guarantee of quality." In any event, I am always much faster the second (or third) time I replace a part. I should teach a class on Land Rover water pump repair.
