Rear shaft can not b put back together
Old Oct 12, 2013 | 07:30 PM
san988's Avatar
Default Rear shaft can not b put back together
As a part of the u joint replacement I took the shaft apart (2pieces) and now I can't put the 2 pieces together. It just does not get back in. Can anyone tell me what am I doing wrong?
Old Oct 12, 2013 | 08:17 PM
NiteTrain's Avatar
are you using a lot of grease? Also, did you index the two pieces so you could put them back together the same way they came apart?
Old Oct 13, 2013 | 06:58 AM
san988's Avatar
I made the mark but with all the grease I am not sure anymore if I am doing it in the same spot. Need help
Old Oct 13, 2013 | 03:05 PM
san988's Avatar
Ok problem was solved. For those like me (benigers). There is a guide (mark) in one of the arms that hold the U Joint and another inside the long part of the shaft. Just make sure you align both and the 2 pieces will be together like butter.
dusty1
Dec 15, 2013 07:48 AM
rlrigsby
Apr 10, 2010 04:58 PM
mcrw
Jan 29, 2009 07:48 PM
adowgiert
Jan 22, 2007 06:02 PM
