Rear Wiper Relay
Old Aug 7, 2018 | 05:14 PM
Fast951's Avatar
Default Rear Wiper Relay
My rear wiper won't complete a full cycle before the relay clicks and stops the motor which parks the blade in the middle of the rear window. Imagine I need to replace the relay responsible for the intermittent function for the rear. Anyone know which one it is?
Old Aug 7, 2018 | 09:06 PM
JUKE179r's Avatar
I’d start at the switch on the dash to make sure you have a secure electrical connection. Or swap the switch with another switch from the dash to verify if it is or isn’t a bad switch. Check the pivot point on the rear motor to make sure the wiper arm is tight and not loose. Have someone move the rear wiper arm when you press the switch. Sometimes that helps unjam the sticking motor.
For the relay, check the auxiliary circuits relay, R7 under the bonnet. Fuse 18 in the cab is the rear wiper motor fuse.
Old Aug 8, 2018 | 09:38 AM
Fast951's Avatar
Thanks. All the mechanical bits are sorted and the motor has power so I'll try swapping R7 to see if that makes a difference. I'm thinking the BCM may have some role in this mystery. Seems the rear wiper relay does not stay energized long enough to allow the complete back-and-forth motion of the wiper arm. Possible it could be the motor, and I have a spare so I might try replacing that if R7 is not the culprit.
lipadj46
Apr 19, 2020 11:56 AM
aBs0lut30
Jan 23, 2017 10:33 AM
slskier88
Feb 18, 2015 01:34 PM
meltdowndave
Oct 30, 2009 11:05 PM
chapman4308
May 23, 2008 06:36 PM
