Replace the front double cardan with a single cardan?
Old 11-17-2015, 01:22 PM
Dave03S's Avatar
It will be a slightly greater angle once he gets some tires with tread.
  #32
Old 11-17-2015, 01:54 PM
fellipe's Avatar
I am running bfg 275/65/18
  #33
Old 11-17-2015, 02:44 PM
Alex_M's Avatar
Tire size won't change the driveshaft angle unless he lifts more, which doesn't sound like what he's planning.
  #34
Old 11-17-2015, 10:29 PM
Bom2oo2's Avatar
fellipe, as you said it might never have vibrations, & if you grease it often it might even last a very long time & never fall apart, but does anyone know for sure that it will not damage transfer case bearing that it's connected to or wear it out sooner than,? I am not saying that it will, but there is a possibility because of the angle, & that might be the reason LR decided to use a more expensive driveshaft in this case,
  #35
Old 11-18-2015, 05:35 AM
fellipe's Avatar
Your line of thoughts definitely makes sense... Is there something I can do to check it periodically? (maybe check for play or something?)
  #36
Old 11-18-2015, 06:18 AM
coors's Avatar
Iideally you want the two ends of a double-ujoint drive shaft within 1°-2° of each other for maximum u-joint life and minimum vibration. This is actually the operating angle (under load) and not the angle of the drive shaft to the u-joints themselves (that has its own limit).
Since the rear pinion moves up under acceleration (unless you have anti-wrap control on the axle) ideally you set up the static pinion angle to be 1-2° below the transfer case output flange angle. This way, as the pinion twists up, it comes into a good alignment with the transfer case.
Stick an inclinometer on your setup and let us know what you have it set at.
  #37
Old 11-18-2015, 12:33 PM
mln01's Avatar
This is probably overkill but here is a chapter from what appears may be an automotive tech textbook describing driveshafts and u-joints (including double-cardans) in mind numbing detail.
I tried to find a workable link for it instead of attaching the doc itself but had no luck. I'm 99% sure it was contributed in another thread a year or more ago by Tom Rowe (antichrist).
File Type: pdf
OffroadFrance
05-22-2015 05:47 PM
geek_IM
12-15-2013 11:27 AM
roverbob
01-16-2013 03:04 PM
CANAMDiscovery
12-19-2012 09:40 AM
Quick Reply: Replace the front double cardan with a single cardan?
