Replacing The Battery Ground Cable
Old Jan 1, 2023 | 01:35 PM
HoosierMan's Avatar
Default Replacing The Battery Ground Cable
So I have finally gotten around to replacing the negative-engine block ground because the original terminal is getting loose and insufficient. Got the new cable from BA and removed the old one, go to bolt it to the engine block and I lost the bolt. Now this has happened three times and the first two times I got very lucky, only this time I cannot find the bolt. My question is what size bolt is it? I have a hardware store near me that's usually well-stocked on everything even down to the weirdo ones no one ever seems to use.
Just to be clear, it's the bolt used to connect the battery negative to the engine block. I need to know what size it is so I can get a replacement.
Thank you.
cvhyatt
May 15, 2019 08:07 PM
RoverCraig
Feb 3, 2019 07:06 PM
ammonation
Aug 30, 2015 08:55 AM
antichrist
Mar 29, 2011 08:41 PM
karover
May 28, 2010 07:05 AM
