S and M lights!
Old Aug 28, 2018 | 07:29 PM
Extinct's Avatar
Get an elm327 bluetooth code reader off of Amazon and either the Torque app on Android or Car Wizard on Apple to clear the codes. New battery or clean the connections. You will be good to go.
And thanks for your service - hit me or the forum up any time -you will get special, personal service.
Old Aug 28, 2018 | 10:47 PM
Charlie_V's Avatar
I paid cash for a new transmission in 2004 (shop said I needed one). I later found out (when the same symptoms returned on the drive home with the new transmission) that it was the battery. As others noted, poor grounding can also cause the problem.
The other time I had them, the cable connection just behind the gear selection mechanism on the driver side of the transmission was not connected (my fault, after replacing the wiring harness).
There are other possible causes but those are easy to check.
Old Aug 29, 2018 | 09:15 AM
OffroadFrance's Avatar
Originally Posted by mln01
There are something like 14 different faults that can trigger the flashing M & S lights and limp home mode. To diagnose it correctly you'd need a code reader that can read transmission codes. Most lower-priced scanners read and clear engine management codes only.
That said, the most common cause of the flashing M&S and limp mode is low voltage, which is why others are telling you to clean the battery connections and the grounds.
X1 .................. without DT codes and clearing them plus a fully charged battery you might as well pee into the wind.
Old Aug 30, 2018 | 05:43 PM
badkarma's Avatar
6th Gear
Thank so much. I found that if I don't shift into reverse it's fine. It seems like it's the neutral safety switch? Maybe? Lol. Damn times like these I miss Afghanistan.
Old Sep 13, 2018 | 03:23 AM
JUKE179r's Avatar
This morning I got the P0705 trouble code when I was driving up levels in a parking garage. My S&M lights were flashing and somehow I lost gears. Even though I was in "Drive", I pressed the gas pedal my Disco started rolling backwards like it was in Neutral.
I rolled backwards to safe spot in the garage, cleared the P0705 code with my Nanocom and drove off like nothing happened.
My battery connections are good and I never had that happen before. Weird...
Old Sep 13, 2018 | 08:47 AM
Charlie_V's Avatar
Now that's freaking STRANGE
Old Sep 14, 2018 | 05:35 PM
Tidder's Avatar
Mine was showing S and M, as well as stuck in limp mode. I tried all the forum fixes, new battery, xyz thing, was even eyeballing a new transmission control unit thing. Turns out the dang electrical connector on the side of the tranny was broken and not making a good connection. Took it off, cleaned it up with some contact cleaner, epoxied the broken spots, and plugged it back in. Everything worked great at that point, made me feel like a real idiot. As a communications and tech guy, "is it plugged in?" didn't even pop in my brain until I already threw a bunch of cash at it.
Old Sep 14, 2018 | 06:52 PM
Charlie_V's Avatar
Doh! Those parts would have failed anyway... you are good for a long time now.
Old Sep 25, 2018 | 11:29 PM
No Doubt's Avatar
Any update?
Reza
Jun 30, 2022 06:38 AM
smittyrc
Dec 23, 2013 08:37 AM
happy1ff
Jul 12, 2013 09:21 AM
tarpon66
Jan 31, 2013 06:18 PM
rekogniz1
Nov 5, 2009 12:19 PM
