SERVICE QUESTION?
Old Feb 6, 2009 | 01:49 PM
salve7's Avatar
Default RE: SERVICE QUESTION?
How can I tell if my 01 has the CDL nip without reaching under there? I tried feeling around and couldn't tell what I was doing even after consulting RAVE and a pic someone posted on here for me. Is the cut-off exactly mid year? (as in June and up, no CDL) and can I find that on the door sticker or other such place? And not being mechanically inclined myself, is this something that a local mechanic can do or the LR dealer (last resort)?
EDIT: I looked on the door and it says 03/01 so i am assuming that it is considered early year. If this is the case how OEM does the $100 plus labor parts look? Is it the shifter with the option to go lock or is it a jerry rigged option?
Old Feb 6, 2009 | 02:14 PM
okdiscoguy's Avatar
I am not sure of the cutoff time. Mike should know.
I was just talking about getting the linkage from e-bay or a salvage from a D1. dweb has a write up for a solenoid actuated shifter that is controlled by a factory fog lamp switch mounted on the binnacle. The solenoid is a little more trick than the linkage, I think Mike did his this way and really likes it. The D1 linkage looks just like the 04's. Totally stock. I was a little off on price, they are $150... http://www.roverlandparts.com/1994-1...seshifter.aspx
You can spend under $20 if you are handy and make a lever outside the truck, but it is like having locking hubs on an old 4X4. You have to stop, get out and lock it.
Old Feb 7, 2009 | 01:34 AM
IDAHODISCO's Avatar
http://www.autotrader.com/fyc/img_po...357&photoIndex
What do you think? What should I exspect whith this one????
I am thinking $4,200 I havent seen it but heard it start today first try over the phone!! The sale guy sounded happy to be in it said the 200 mile's, I need to dive to see it would be worth it!
What should I look for on this one?
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
theMar
Freelander
Dec 25, 2008 07:56 PM
kchao2000
Freelander
Feb 19, 2008 09:24 PM
JKK
Oct 13, 2005 10:49 PM
