Shifter Stuck In Park
Old May 17, 2009 | 06:57 PM
mellyagaunce's Avatar
Default Shifter Stuck In Park
Hey, have the same problem as a lot of people on here with my Disco 1. My shifter is stuck in park. I have tried what most people have said on the forums already. I bypassed the rear window defrost with paper clips. I have brake lights. I have taken the cover off the shifter and pulled the pin up with pliers. I'm kind of at a loss right now. Any ideas on what it could be.
Old May 17, 2009 | 08:09 PM
Replace the brake light switch.
Old May 17, 2009 | 10:28 PM
sloppyjoe's Avatar
brake switch,,,,
Old May 18, 2009 | 02:17 AM
RamblingMan's Avatar
To test if its the brake switch, pull the plug off of it and run a jumper wire across the leads. If shifter changes while jumped then its the switch. Remember to remove jumper before driving off or else brake light will be on.
Old May 18, 2009 | 11:18 AM
From what his post states, he has brake lights and he has already tried jumping the system thru the rear defroster.
I am thinking a shift solenoid has failed.
Old May 18, 2009 | 06:44 PM
How would I test to see if it's a shift solenoid?
Old May 18, 2009 | 08:08 PM
Hot wire it or use a test probe to verify a current to the solenoid.
Roywilliams14
May 17, 2014 01:27 PM
ImQuattro
May 1, 2014 08:36 PM
KlamathMatt
Nov 4, 2013 12:19 PM
Scope
May 2, 2013 03:54 PM
cstocks
Jan 17, 2009 10:43 AM
