Shutdown! Help!
Old Mar 26, 2012 | 01:40 PM
sonya2020's Avatar
3rd Gear
Exclamation Shutdown! Help!
Hello Everyone, Hope Everyone is having a great Day. I Was Driving My Disco,Today When all of the sudden I Passed thru some railroad tracks,and My Truck shutdown all of the sudden,I was able to pull over to the a Bussiness,Opened my hood and made sure everything was alright and it was water temp was normal, Truck had oil, Everything its just that when i go to start it everything turns on (Lights) Just the truck wont. Perhaps it could be a sensor that went off? Thanks So Much For your Help!!!
Old Mar 26, 2012 | 02:43 PM
leadfoot's Avatar
More than likely is the inertia switch that is supposed to shut off the engine in case of accident. Since you mention the rail road, that bump may have triggered it. It is in the engine bay, fire wall, passenger side. Re-set it and it should start right up.
Old Mar 26, 2012 | 02:48 PM
yloDiscoII's Avatar
Next thing to check would be the Crankshaft positioning sensor. If the truck shuts off when it gets warm, then will start up once it's cooled off, that would be it.
It is a PITA to replace, so hopefully it's the inertia switch.
Let us know what you come up with.
Old Mar 26, 2012 | 08:42 PM
sonya2020's Avatar
3rd Gear
Thanks So Much For The Help! My truck is Back Running, Thank GOD! Thanks So Much Everyone Really appreciate it!
Old Mar 26, 2012 | 08:49 PM
So if it was the inetia switch - had you been in an accident it would have killed fuel pump, to reduce fire hazard, and unlocked all the doors if you had them locked. Hopefully this is the most you will test this feature.
Savannah Buzz
Off Topic
Oct 16, 2013 01:29 PM
Speed racer
Oct 11, 2008 10:56 PM
willlane
Jul 13, 2008 10:28 PM
sysroute
Jan 21, 2008 08:23 PM
