Slipped Sleeve Syndrome - I think!
Old Dec 17, 2012 | 05:55 AM
mrsshimmy's Avatar
5th Gear
Default Slipped Sleeve Syndrome - I think!
I own a Disco II V8 2002 & in the mornings when I start the cold motor there is a "knock" in the motor - not a tap but when the motor warms up to running temp the knock goes away. I was told this is a loose piston sleeve & it's pretty much a full strip down of the motor which financially probably won't be possible....I've noticed this noise for a while now & the car has been used still ok. Is this a problem that can be left without any concerns? Or, is there another solution to my problem?
Old Dec 17, 2012 | 07:07 AM
It is not usually the slipped sleeve, that is quiet at start and comes on when warmed up and sleeve begins to move around. More likely just worn internal parts, like bearings; and/or low oil pressure. In our tech area is a review of oil and filter that could help. Bearings could also be replaced while engine is in the truck.
See https://landroverforums.com/forum/di...estions-46975/
and https://landroverforums.com/forum/di...rite-up-48197/
Attached Thumbnails Slipped Sleeve Syndrome - I think!-30023360413_large.jpg
Old Dec 17, 2012 | 09:11 AM
That knock is destroying your engine the longer you avoid having it checked.
rudawski
Apr 18, 2023 07:17 AM
Jared9220
Oct 30, 2012 04:23 PM
ltbrkm3
May 15, 2012 10:27 AM
molendast
Oct 13, 2011 09:19 AM
CurlyE
Mar 10, 2011 09:10 PM
