Smog time - Got check lights need sorting out
Old Jul 2, 2017 | 09:56 AM
MPDano's Avatar
Default Smog time - Got check lights need sorting out
Hello all,
It's that time of the year again. I got the below check codes. I replaced all the intake gaskets and the injector o-rings a couple years ago. Stayed CL free for a year, but got these codes last year. I need to sort this out before getting it smogged. Any thoughts? Vac leak somewhere?
P0733 - gear 3 incorrect ratio
P0174 - Bank 2 lean
P0171 - Bank 1 lean
Old Jul 2, 2017 | 10:47 AM
abran's Avatar
I'm guessing mass air flow sensor with that incorrect gear ratio coupled with lean codes.
get brake cleaner and spray all along intake and vacuum lines post MAF, if the engine idle changes it might be a leak and not MAF.
Old Jul 2, 2017 | 12:03 PM
MPDano's Avatar
Thanks Abran. I am also leaning towards the MAF as well. Not sure if I replaced it when I bought the car 3 years ago. Got a OEM Bosch on order with NAPA. If that doesn't solve it, then I'll move to checking for leaks. Never tried the propane gas trick but I'll give that a go.
Old Jul 2, 2017 | 01:23 PM
abran's Avatar
Just to clarify, I suggested using brake cleaner, not sure if that has propane gas in it.
good luck
Old Jul 2, 2017 | 03:02 PM
MPDano's Avatar
good luck
Yes, I know you didn't suggest it. I just heard using propane gas works as well.
Old Jul 9, 2017 | 10:37 PM
MPDano's Avatar
Replaced the MAF with a new Bosch one. Reset the CL and it's staying off for now. Just need it to stay off while the system gains the time to be ready to smog.
Old Jul 10, 2017 | 11:22 AM
MPDano's Avatar
Passed smog! Had it hooked up to my OBD reader to monitor once it was ready, then went straight to my local smog guy. Nice not to see that CL everyday.
Old Jul 10, 2017 | 01:48 PM
Alex_M's Avatar
Glad that fixed you up, but if you're waiting to fix issues because of SMOG and not because your truck is having an issue it's not going to live long or be reliable for you. Especially with an issue like running lean. That's terrible for your engine.
photo2u
Sep 4, 2016 03:23 PM
Proto31
Feb 6, 2015 02:36 PM
USNAVYORDNANCE
Jan 2, 2015 09:58 PM
Joshman
Mar 3, 2014 11:30 PM
brianb883
Sep 21, 2009 12:33 PM
