soft brake question
Old Sep 19, 2014 | 05:25 AM
stb616's Avatar
Originally Posted by OffroadFrance
Purely a guess without seeing/testing as it could be many things but, I guess it's an air in the system problem or the hoses need replacing or both. However, it could also be brake pad push back on the caliper(s) due to slack wheel bearing(s). Another possibility is the vacuum line to the brake servo is leaking or even the servo defective. Lastly it could be the master cylinder seals defective. It's a process of logical elimination I'm afraid.
Stupid question I know, but how do check for slack in the wheel bearing? I've had it off the ground and everything seem tight in the front end....like how you'd check ball joints. Anything else need to be done to check the wheel bearings?
Old Sep 19, 2014 | 06:10 AM
drowssap's Avatar
your wheel bearings are part of your hubs, so it all or nothing when it comes time for replacement
Alex_M
Nov 27, 2014 01:05 PM
hotdogpimp
Apr 27, 2009 12:21 PM
Phototone
Apr 4, 2008 04:30 PM
reconram
May 9, 2007 08:43 AM
jwmstang
Apr 12, 2007 03:46 PM
