Stalled...?
Old Feb 13, 2017 | 08:36 AM
collector87's Avatar
Default Stalled...?
Hello!
Truck seemed to stall this morning, never happened before:
-Blizzard happening outside
-Truck warmed up for maybe 10 minutes while cleaning it all off - running fine
-Drove about a kilometer - running fine
-Stalled when driving maybe 40 kph - accessory ignition setting lights on
-Wouldn't restart - turned over but engine didn't kick in - electrical power just fine
-Scanned for codes - nothing
-Tried to restart again - started up fine, working fine now, have restarted many times since
-Drove to shop - no codes there either, everything seems normal
-Checked air intake just in case - filter and MAF grill a tiny bit dirty - blew out with air (parts stores closed in blizzard), a little surface oil past the MAF in the pipe, a little water under the air filter but filter was quite dry
Any ideas?
Thanks!
Old Feb 13, 2017 | 09:46 AM
Red5's Avatar
I'm betting on a bad CPS. Pretty common issue.
Old Feb 13, 2017 | 09:49 AM
abran's Avatar
damn "child protective services"...
Old Feb 13, 2017 | 10:13 AM
Thanks Red - found these links, I guess I'll drive it in town only for now and see if it stalls again...
https://landroverforums.com/forum/di...000-dii-25610/
Sensor: Crankshaft Position BOSCH Engine (ERR7354 Same Fit As Part # ERR7354 ) - Land Rover sensors from Atlantic British
Old Feb 13, 2017 | 01:21 PM
OffroadFrance's Avatar
Bearing in mind LR's are notorious for ECU software glitches it'll probably never happen again. My TD5 regularly has an ECU 'wobbly' and sometimes there is months where there's no problems. I believe it's sometimes caused by stray EMF signals or a cell phone signal, who knows eh.
Old Feb 13, 2017 | 01:23 PM
You are probably right Abran
hampshier32000
Feb 8, 2011 09:45 PM
froggyj44
Mar 19, 2010 08:19 PM
mattkon
Feb 24, 2009 11:06 AM
jcdephi
Dec 9, 2006 11:37 AM
jcdephi
Defender
Dec 6, 2006 11:36 PM
