Starting Problems with Disco II
Old Jun 18, 2013 | 06:36 PM
jfall's Avatar
Do these things:
1) Clean battery terminals with circular wire brush that fits inside the terminals
2) get a NEW battery. Don't laugh. Walmart $110
3) Trace large black wire from the battery- make sure it goes to the frame. Clean the connection.
4) Trace the braided THICK ground wire from the firewall to the driver's side head. Make sure that wire is there.
After all this work, if it still does not go ---
May be the starter is trying to extend the bendix into the fly wheel and the bendix is not extending.
the hummm would be the starter motor running with no load.
the starter may FLY APART as the engine will RPM limit it. Starters are not meant to run with no mechanical load on them.
Old Jun 18, 2013 | 06:43 PM
And the starter gear will create a metal "fuzz" that will make the CKP sensor turn off sparks....
And I just pulled my heads, had a neekid ground stud. Love the quality PO work.
Note for the city slickerz - "naked" means you a'int got no clothes on. "Neekid" means you ain't got no clothes on and you're up to sumthin'.
Old Jun 19, 2013 | 10:32 AM
SuperSport's Avatar
I'm ALWAYS "Neekid"!
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
daniep
Sep 13, 2009 01:21 PM
DiscoOn22s
Dec 11, 2007 12:39 PM
GoDevilGper
Aug 16, 2007 07:28 AM
baysiderover
Oct 6, 2006 06:58 PM
