steering wheel wobble wobble…2000 Disco
Old Nov 5, 2015 | 03:30 PM
kristofferzen's Avatar
Default steering wheel wobble wobble…2000 Disco
I have a 2000 discovery II. Been doing a lot of renovations. So I just replaced the factory wheels with steelies from Rovers North,
Also replaced the tires 265/75/16. In the last year I put a 2 inch lift kit
from Terra Firma as well.
Now, After recently getting the tires and wheels I noticed a wobble of the steering wheel around 40 miles an hour to 55 or so. Not uncontrollable but enough to cause a little worry. I took the truck to a local dealer for an
alignment and balance. Drove fine last night and the wobble has started again…..Any suggestions??
On a side note….I noticed a wobble in the steering wheel and had a tie Rod end replaced a year ago. I noticed it was around 55 miles an hour and really scary to drive at the time…The wobble was much much worse than it is is now. I also recently had a tie rod replaced…..
Old Nov 5, 2015 | 04:08 PM
Twix's Avatar
How's your steering box? Anything leaking out of it? I think that's a common problem with these trucks. I'd also look at the steering damper and the pitman arm.
I had a bad wobble in my truck when I bought it, took it in to my tire guy and he said I had no wheel balanced. One was out 7 1/2 oz! Once he did that, my shake went away. Maybe that's your problem as well.
Old Nov 5, 2015 | 04:22 PM
acg's Avatar
acg
To the OP,
Just to clarify, did the same wobble exist before you switched to the new steelies? Or is it a different kind of wobble?
Old Nov 6, 2015 | 07:11 AM
Originally Posted by acg
To the OP,
No the wobble started after the wheels were installed. Then I took it in for a
balance and alignment. It seemed ok then within a day it went back to a slight
wobble. Not a death wobble but enough where there is a little play in the wheel and I feel a little uncomfortable. It was definitely not there prior. I don't
know if a weight was thrown off after I was driving or not.
Old Nov 7, 2015 | 07:14 PM
Default wobble continues
Well…I took it into another shop a local chain. They said there was nothing wrong with Alignment, Balance, Ball Joints, or Tie Rods/Ends.
"It's because you have a lift on your truck".
I told them I didn't have the wobble until after the new wheels were installed.
So any other ideas or it is just the result of a lift and larger wheels? 265/75/16 sized wheels with steelies from Rovers North.
On a good note, I got a new Thermostat from BPUH and it has dropped my running temps by 15 degrees! Now in the 180s/low 90s.!
super90
Jul 31, 2010 06:08 PM
kenk
Feb 15, 2010 09:51 AM
Rover Chris
Dec 12, 2009 07:53 AM
Clunker
Sep 11, 2008 12:24 PM
thesearch35
Feb 14, 2007 10:44 PM
