Steering wooble
Old Feb 2, 2009 | 02:23 PM
kpsxtyone's Avatar
Default Steering wooble
Hi,
I just got a used 97 Disco, there seems to be a problem with the car going straight when i hit a bump or a rumble on the road at around 100 km/h, i had to correct it to go straight (was scarry as if the disco was fishtailing) however at around 70 and hit a bump its not too bad. It doesnt seem to have a dead spot when trying to steer with small movements.
What should i check? would it be the stabilizer shocks? or something else
thanks !
Old Feb 2, 2009 | 02:31 PM
redhotbuzz's Avatar
Default RE: Steering wooble
steering damper good place to start . . ball joints ,pitman arm .Flushing power steering. front suspension ,tires,cv joint.... welcome to the world of LRs
Old Feb 2, 2009 | 02:35 PM
NiteTrain's Avatar
check all front suspension components...radius arms, track bar or panhard bar which ever rover uses, check wheels for excessive play..if you are not sure what you are doing take it to a good alignment shop they will inspect it before doing an alignment.
johnkbl
Sep 21, 2023 06:17 AM
JoMar
Jun 26, 2013 06:20 PM
jycsalas
Apr 17, 2009 02:21 AM
The Image
Jan 5, 2008 05:43 PM
Evian
Aug 18, 2005 11:34 PM
