Stranded again, sputtering/no power, won't crank
Old Nov 16, 2012 | 09:20 AM
Evap pump (under truck) is not the same as a fuel pump (in the gas tank). It is a small pump that makes pressure in the fuel recirculation system to detect a leak of one size or another. See attached pix and diagram from RAVE.
File Type: pdf
File Type: pdf
Old Nov 27, 2012 | 07:05 AM
pwaltrip's Avatar
Haven't had time to work on it yet, but is this a dumb question, can I get a used fuel pump? I know that it's probably not a good idea but I'm not wanting to spend $400 on one. If I can get it running, then I can use it as a trade. Also, my p1450 code, anyone know where I can find a used evap pump/motor, I think I should start with that for that issue, but they are expensive too? Thanks for the help everybody!
Old Nov 27, 2012 | 07:18 AM
lr2001silver's Avatar
Banned
Yes you can find a used fuel pump at a salvage yard but you will need to know if you have secondary air or not. You have trade ideas in mind?
Old Nov 28, 2012 | 07:11 AM
pwaltrip's Avatar
Yes, I have secondary air injection. Yes, I am wanting to get rid of this money pit. I love the truck, for the 10 minutes when everything is working correctly. I haven't even been able to go off road because I'm too scared it will leave me stranded, I was ok with doing some work here and there, but I have spent a few grand already and have atleast a few more before all issues are resolved, and as a daily driver...need more reliability. But, from what I've already seen, trade in value sucks too, truck is pretty clean, had a dealer offer me $1250 for it as a trade? WTF? So I guess I'm stuck with it. If that is the case then maybe over the next few months I can tackle everything else and then have a toy. I got another vehicle now so the rover can just be parked for now.
Old Nov 28, 2012 | 09:27 AM
Banned
Yea you will not get much for trade in unfortunately. Money pit not so much the parts are cheap and its just a truck if you can do the work on it yourself you can overcome the issues. I just had a truck towed in to me with a code that nobody knows anything about not even buzz or Disco mike could help me out with it its bad bad bad when those two wizards dont have a answer for you. With in a few days i beat that code and all problems are gone and its back out running around!!!!!!!!!!!!!!! Dont give on your D II buddy.
nosup4u
Jun 16, 2014 02:54 PM
kleener
Jul 12, 2013 08:06 AM
knucklzluvsrovers
Mar 10, 2011 09:07 PM
2000 DII
Dec 20, 2008 09:01 PM
