Stumped with hazards flashing, no start
Old Jun 7, 2020 | 08:50 AM
RoverSE7's Avatar
Originally Posted by frostythor
yes flashing 4 way light and not starting is the immobilizer circuit, when I had it no matter how many times I reset it did not start, it did after I removed the wire individually and cleaned the all flashing stopped and it started first turn of the key
Hi I have the same issue Flasher on Wont start.... What wire did you unplug? to what device? I just tried swapping out the inertia switch from another LRD2 i have. Still no start Flashers on AND i have these Green geared M & S icons flashing. NO alarm LED or anything... I am stumped
Old Jun 7, 2020 | 09:18 AM
scostagl's Avatar
Trace the wires from inertia switch to the fuse box. See if you have any frayed or damaged wires. That’s likely the issue if you’ve already tried replacing the switch.
Old Jun 7, 2020 | 11:10 AM
frostythor's Avatar
I pulled the wire off the inertia switch and cleaned them up, luck for me that was all it was, but it only needs one wire in the system to earth and its a no go
Old Jun 8, 2020 | 05:43 AM
RoverSE7's Avatar
Default White & Green wire to blame!
I found the issue under the fuse box by advice from another member in another thread. The White & Green wire was corroded right through creating and open circuit to the Inertia switch. Once repaired Bingo! Engine started and flashers went off.
Thanks to all guys & gals on this forum to help each other out. I will do my part as i can. Thanks Again!
ducmed
Feb 17, 2021 02:11 PM
Kadin Wallner
Mar 19, 2020 11:05 AM
silvertank
Jul 30, 2013 05:05 PM
flanker6
May 25, 2013 06:48 PM
luckyducky83
Jul 19, 2009 05:39 PM
