Suggestions for a replacement window regulator roller or slider
Old Apr 5, 2009 | 06:47 PM
Originally Posted by Disco Fuego
"1. Also fits Disco Series II fitted with round rollers"
That's hilarious! I was really looking for some square ones, cause... Never mind! That just cracked me up.
Been reading Dr. Seuss again havent you?
Old Apr 6, 2009 | 10:01 AM
jrkstore43's Avatar
I got a front passenger side regulator from these guys a few weeks ago for my 2003: http://www.importpartsspec.com/home
It was around $55.
Old Mar 20, 2012 | 06:37 PM
matnoy's Avatar
Default Window Regulator Continuing issue
I have noticed after replacing twice the passenger window regulator that the window itself was not mounted flat to its bracket. After removing the upper door frame and removing the window, I was able to level the mount with a rubber mallet. The window seems to go up and down more parallel now. Just a thought when you are replacing to check.
Old Mar 20, 2012 | 07:36 PM
And for you old squares, https://landroverforums.com/forum/di...ight=regulator - BTW, someone did post about stock Range Rover square sliders.
Old Mar 20, 2012 | 11:07 PM
Big Jim Swade's Avatar
You might try Rockauto.com, I got a new regulator for under $50 when I replaced mine.
Old Mar 22, 2012 | 05:47 PM
BMF175's Avatar
I've had to fix my driver side regulator a couple years ago. The regulator was so twisted up and parts were bent. At the time I was on college and buying a new one wasn't an option. I went to home depot and bought four white nylon bushings. Heated the center slightly, slid them on and used a pin to hold in place. I bent the regulator arms back straight and haven't had problem with it for 4 years and 2 hours and 85 cents!
LRD2&ME
May 23, 2021 07:57 PM
parkerlander
Jul 25, 2013 09:52 PM
FieryRebel28
Nov 20, 2012 09:03 PM
malibutj
May 6, 2011 10:57 PM
slave600
Oct 11, 2008 08:51 PM
