tc hd abs
Old Apr 13, 2009 | 02:05 PM
sforb's Avatar
Default tc hd abs
When the 3 amigos are on does the TC HD still work ,1999 D2
Old Apr 13, 2009 | 02:34 PM
That depends on what is wrong.
If it is a bad wheel speed sensor then it wont work on that wheel, if it is the slabs unit then it might not work at all, but it might work sometimes.
To many what ifs to say for sure.
I would just assume that no it wont work.
Old Apr 13, 2009 | 02:49 PM
Normally no. If you have a minor glitish caused from squeaky brakes as an example, your ABS may still work. The only way to tell for sure would be to throw a panic stop on a loose surface and see if you can still feel the ABS pulsate thru the brake pedal.
Let us know if the ABS is still alive.
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
