Temps after a new head gasket?
Old Jan 14, 2013 | 04:02 PM
mongosd2's Avatar
That is not right, you have a issue. Did the fan hit the radiator in the accident? If it did, it more than likely damaged the water pump, which could be the cause...
Old Jan 15, 2013 | 01:32 AM
180 stat. Re-check coolant level and belt route. Thermostat should be last thing worked on in cooling system, the tiny hoes in top leg can easily become clogged with junk knocked loose.
Attached Thumbnails Temps after a new head gasket?-land%252520rover%252520thermostat%252520005.jpg
Old Jan 15, 2013 | 09:44 AM
KindaGuitarded's Avatar
Thermostat is brand new(had it changed when they changed the head gasket) System flushed and refilled with NON-Dexcool global coolant. Electric fan comes on around the 200f range. System air-bled , hoses are firm and hold pressure.
What worries me is that my temps are probably spiking around 225 once i shut the engine off. After spending 2500 on a head gasket job, i'm overly paranoid.
Old Jan 15, 2013 | 09:49 AM
ZGPhoto's Avatar
You should be paranoid at 225...
Old Jan 15, 2013 | 11:19 AM
A moment please. Temps are at somewhere before you shut down, then increase to 225 once rotation of the engine is reduced to 0.0000 rpm, and water flow is reduced to 0.0000 gallons per minute. It would seem normal to increase in temp when forced water flow and forced air flow is cut off. Then cool back down. I also "discovered" that exhaust manifolds have similar properties and can leave a mark. The D2 is supposed to switch on that electric fan if:
after 10 seconds after key off, the intake air temp sesnor says it is 140F AND coolant temp is 230F.
After 10 minutes, the fan cuts off to conserve battery, or earlier if engine coolant returns to 212F.
So if this is after you turn off the truck, it is expected by physics and Rover is not worried about it unless coolant temp is 230F and IAT is high. So you could have a cold day, wind chill, and an overheated engine and Rover won't turn that helper fan on.
Old Jan 15, 2013 | 04:00 PM
agthird's Avatar
try back flushing your heater core and make sure there is no air in the system...
Old Jan 15, 2013 | 04:17 PM
Bled the system again using the elevated expansion tank method. After i started nosing around under the hood,Drew (the formerLR2001Silver) and i discovered a massive oil leak at the front of the valley pan seal. So back to the shop it went. They assured me they're going to reflush the system and check the thermostat while they redo the head gaskets and valley pan gasket So we'll see what happens.
ImQuattro
Jun 2, 2014 10:55 PM
arod829
Nov 4, 2012 11:12 AM
1stevereynolds
Mar 1, 2010 06:26 PM
scubaman
Dec 16, 2009 07:41 PM
dammad
Mar 5, 2008 07:55 AM
